Greetings from Munich!
Thanks for the insights, if you've got 'em and reply here!
Hazard lights 100% non-functional. Blinkers work. Blinkers do not work when hazard switch is pulled out.
So, I have almost no experience with electrical stuff. The switch is busted...? If so, are the knob and the switch actually one unit, or what? The relay is likely OK becasue the blinkers work...? Or...?
2nd Issue. Have not inspected the brake light switch yet. Apparently it is stuck. The brake lights are always on. Tip or info on inspecting the brake light switch at the pedal? Could the reason be something else?
Thanks again!
Best regards from Bavaria,
Mike in Munich
