Dudes:
Hope you guys don't mind, but I have a few more questions on the clutch replacement.
1. PP tech article, page 3, page 5 of 9 (top of page): "If you can turn the FLANGES on the transmission with the clutch pressed in, you're OK" Q: Where are these flanges referred to located?
2. What holds the Terry cable into the notch on the roller housing? The stock cable had the clip thingy which wrapped around the cable and had a peg which went into the hole in the housing. Will the cable tension hold the Terry cable in? Am I missing a part?
3. It's been quite a while since I removed the starter. Can anyone tell me which wires go where? (red, black (with circular terminals) and white (or is it yellow) with the spade terminal on it).
Thanks in advance for any help!!
Andy...
