I purchased this engine from Mark in January of 2019. Here are the two videos that caused me to pull the trigger.
https://m.youtube.com/watch?feature=youtu.b...p;v=N09sg7wDZ-Q
https://www.youtube.com/watch?v=nyRcs-4UNS0...eature=youtu.be
I got this because I did not want to rebuild the 2.7L I had at the time. Sadly I am not going to use it.
Price. $4500 plus shipping, or deliver for small fee if close enough or the wife thinks its an epic road trip.
Sits today on engine stand. I have several other items for it.
A few oil coolers one on engine is marked as tested.
914-6 Oil cooler adapter from Clevett for the larger oil cooler return
Billet oil sump plate
Few different cooling fans alternators, tin bits, dizzy and wires etc... Seen in the pictures. As you see it in the pictures is what you get. No shroud as I was going to go with clear fiberglass. No Carbs the video was shot with a set of shop carbs. Engine stand and yoke are not part of the deal. Hs been stored in climate controlled garage.
Engine has 930 lower valve covers, fines will need machined for 914 install to clear the inner pivot shaft nut. Oil Cooler needs modified for a 914-6. @MB911 does this service check with him on pricing if you need someone to do the welding.
Thank you Mark for the videos and the SN picture.
