Cool_PA
May 13 2021, 02:28 PM
Hey all, I just disassembled my engine (2.0l 4 cylinder), and inside I found this broken internal piece on a threaded hole. It is next to middle cam bearing. I have a picture attached, is there a way to repair this?
Thanks
BeatNavy
May 13 2021, 02:41 PM
Somebody wasn't following their torque specs while changing the oil...
I don't know if that's repairable. I personally would look for another case.
euro911
May 13 2021, 02:45 PM
That looks like a PO overtightened the oil pick-up tube bolt and broke the threaded fitting
... the torque spec for the bolt is < 7 ft lbs.
I doubt it can be repaired - you'll probably need to source a replacement case half
EDIT: Rob, you beat me to the punch ...
flyer86d
May 13 2021, 03:45 PM
I had one like that on one of my track car blocks. I JB Welded it and was very careful the way I tightened it. Never had a problem.
Charlie
Nogoodwithusernames
May 13 2021, 04:41 PM
If you have a guy that can TIG it is repairable. If he's competent he can weld it without warping the cam boss.
Search T4 syndrome on thesamba.com
Looks like at least a couple people have fixed it.
914sgofast2
May 13 2021, 06:17 PM
Yepp, that is the dreaded Type 4 $yndrome. Either find a good welder and hope he doesn't distort the bearing saddle for the cam bearing in his repair efforts, or just get another engine case from a 914. The cases are pretty cheap, all things considered.
914 cases are largely interchangeable and don't get abused like the ones used in VW Bay Window buses. When you re-assemble your engine, don't over tighten the bolt that holds the oil pickup tube up off the floor of the crankcase and don't over tighten the bolt that centers the oil pickup tube and screen assembly. And do not replace/clean the oil pickup tube screen when doing oil changes. It's not necessary because the Type 4 engine has a real oil filter, unlike VW Bugs. DAPO's tend to think the bolt holding the oil pickup tube & screen in place is the drain plug, like on a Type 1 VW engine. They tend to tighten the heck out of it in a misguided effort to stop all the oil leaks. It isn't a drain plug and their efforts are all for nothing. That 's why the drain plug is right next to it on the bottom of the case.
Mark Henry
May 14 2021, 05:05 AM
It can be fixed if it's a number matching case, if not it's scrap. Even if it was the numbers matching case I'd likely tuck that case under my bench and build on a better one.
Best cases to build on are the 1.7/1.8 case.
brant
May 14 2021, 06:25 AM
Evan
One of the best welders I’ve ever met in my life owns a shop in longmont
He is FAA certified for helicopter blades
Definitely a place that could weld your block
Or I know a shop in grand junction that could do it
VaccaRabite
May 14 2021, 08:21 AM
It can be fixed, but may be cheaper just to get a different case.
Zach
