$250 shipped in the USA
Timing can be set with dip switches or with your laptop for a more custom table.
Type IV sheet metal will need to be slightly modified to fit distributor.
CB Performance Magnaspark Digital Distributor Kit, CB2014 has more power built-in than most EFI computers! 21x21 fully programmable spark table, for the PERFECT ignition curve to benefit your engine and driving style! Programmable Rev-Limiter too!
The Magnaspark Digital Distributor Kit is capable of holding 8 timing maps. It comes with 4 preloaded timing maps
Single Carb
Dual Carb
Turbo, 10psi Boost
For you to choose from. There is also room in the memory for 4 additional timing maps, for you to make and play with. Take an existing map, modify it, and re-name it!
NOTE THIS DOES NOT FIT TYPE 3 NOR TYPE 4 ENGINES, WITHOUT MODIFYING THE COOLING TIN!
Single Carb
Dual Carb
Turbo, 10psi Boost
