Looking for good used, reproduction, new 70-71 turn signal switch.
56kabrio
May 18 2021, 08:45 AM
There's one from AutoAtlanta on Ebay for $75. Hope this helps
Mack
914Sixer
May 18 2021, 04:27 PM
Here you go, click to open. Autohausaz.com
Al Meredith
May 19 2021, 10:35 AM
I have one that is still connected to the console I will sell the whole unit with key or can separate , let me know if interested. AlClick to view attachment
jims914
May 19 2021, 11:59 PM
QUOTE(914Sixer @ May 18 2021, 03:27 PM)
That is a smoking good deal Thanks That's is the same as a type 3 VW and works, just wire color is a little different. Thanks again
RestoReese
May 23 2021, 08:53 PM
I am in the process of replacing mine. First, the wiring has different colors wo be sure to map them before you do any cutting. Next, you will have to remove the pins and resolver them to the new lever wires. Don't cut the wires too short, there is room in in the lever housing if you need to pull the slack out. Last, the pin connector housing is brittle - I broke mine trying to get the lid back on and it is hard to get a replacement.
