I need some help, advice, opinions on a longer term project car.
I have 3 914's. A pretty original 1970 Tangerine that is a driver. A 914 GT clone vintage racer I am refreshing after a long slumber and a 1972 project car I bought several years ago.
My longer term plan is to restore/update the 1972 and then sell the 1970 when it is done.
The question at hand is how far to take the project and what if anything to change. As it sits it is a low mile (80k roughly) very original (other than a repaint in different color) 1972 1.7 that was taken off the road 15+ years ago in anticipation of getting some bodywork done and repaint. The PO bought some new parts, had the bumpers done, etc. I have everything taken off the car in boxes. The rust isn't bad but it does need some help in the rear trunk area, sail panel on one side and jack points. It is very straight otherwise and the interior is really nice. No crack in the dash, perfect mostly. It has a few options, fogs, window defrost, sail panel vinyl.
I am contemplating making some changes but wanted some opinions on how wise these might be;
The current color is red, it is originally a silver car. I don't love silver and would like to do something like Adriatic Blue. I realize long term taking it back to silver may make it more valuable but I'd like to LOVE the color. Thoughts?
The original engine and trans are in the car but I have two 2 liter motors on the shelf and a couple of 901 side shifters and most of the parts to convert the car to side shift. One of the 2 liters has all of the original injection on it. The other had carbs on it. I'm considering rebuilding the carb'd motor up into a mild over bore performance motor and converting the car to side shift and putting the 1.7 and tail shift trans in mothballs. Thoughts?
I have a set of 15*6 Fuchs in storage. I'd likely use the PMB 5 lug conversion kit to be able to use these wheels. Any reason not to?
Anything else I should consider? I'd go through the brakes, suspension, etc. along the way.
My biggest issue is the paint choice but I figure this will be a long term keeper and sticking with a factory color that is popular shouldn't be too big a deal. I love the Tangerine car but I'd like to build one and this seems like a good candidate for that.
Thanks,
Jerry
