QUOTE(Rsjg911 @ May 19 2021, 02:55 PM)
Hi Guys:
So I went to Gas up my 74 2.0L today cause we are moving on Thursday of next week. I couldn't get her into 4th or 5th even from a dead stop.
Any ideas/suggestions on a fix/possible cost to have work done?
Thanks much all!
I am wondering if maybe you have a sheered roll pin in your shifter at the trans. Check ball end, or internal, since it appears all of your external stuff should not be causing this. Are you able to put the shifter into the 4-5 plain? I would still suspect the engine to bar mounts unless you tried to lift engine with jack to assure they are not torn. Check bolt on coupler in tunnel at bottom of the shifter in cabin, the one that clamps onto the splined end of the intertunnel shifter rod.
