QUOTE(Retroracer @ May 21 2021, 12:18 PM)
So - yes and no!
Yes: it would seem that the fix is "simply" realigning the needle on the shaft, but..
No: in that you'll have to pry off the bezel off to get access to the needle. Removing bezels is a bit of an acquired skill / art form, and its easy to munge one up unless you're well practiced. Given the case you've had your speedo rebuilt, they probably replaced the bezel with a new one - in which case I'd suggest getting either the original shop to fix the issue or contact someone like Palo Alto Speedometer to make things right.
- Tony
Understood, I "munged" one up from an old Italian motorcycle! Thanks
