QUOTE(VaccaRabite @ May 26 2021, 09:00 AM)
Is this a new problem?
I first have to suspect the battery. How much charge does the battery have? At about 10 volts its essentially dead.
If you have 12.6 volts at the battery, check the ground strap from the battery to the chassis. It has to be attached and tight to both the battery terminal and the chassis bolt.
If its not one of those you need to start checking fuses (under dash board above the clutch pedal.)
Lets see. Could be a bad ignition switch, as your switched power will go through that. And those do fail.
If its not a fuse then you need to look at the wires going from the battery to the fuse box and the wires going from the fuse box to the dash board. But at this point, I think its unlikely to be wires as you have several circuits that have failed.
Zach
Zach,
Thanks for the suggestions. This is a new problem. The car was running a little rough, especially at cold start. I also need to replace the emergency brake contact switch. I do not think these are related. (At least not the ebrake)
I will check battery voltage, but the battery is only about 12-14 months old.
Nothing has power, interior light, dashboard, instruments, headlights, etc.
Regards,
Terry
