assuming this is 1.8 with L jet injection intact.
there is a quick test you can do for fuel delivery if you can't get a pressure guage.
pull a fuel line off the injector ring at the return end, after the injectors.
get a measuring jug. mark off 0.5 L or 500ml. take the air cleaner hose/plenum off that connects to the throttle body. push the air flow flap open inside the end of the aircleaner housing with the ignition on. the fuel pump won't run in a 1.8 until you crank to start or do this procedure. time 30 seconds and turn ignition off or let flap go. you should have 500ml or thereabouts in the jug.
you might need two people to do this as its a bit awkward. one to hold the hose in the jug and one to push the flap open. but you might be able to manage it alone.
its part of the fuel delivery test anyway as it measures delivery flow. pressure is the other half of the equation.
all that is for a 74 with the pump under the engine, but i think it would be similar for a 75 which has fuel pump in front. its got to get that fuel delivery and pressure at the engine.
also a 75 is pushing the fuel at pressure through the cabin, so if there is a leak its going to flood from the front and pool at a fair rate if its after the fuel pump up in the front there.
it could also be your fuel pump is cactus. this test will tell you. or its not getting fuel. same thing in the end.
if the fuel is getting to the engine and the end of the injector circuit, move on to other issues.
good luck -- fuel pooling at front is a sign of an issue, but it might not be all the issues
re engine will attempt to start?
do you mean it runs for about 5 to 10 seconds?
if so that means about a 90% chance its starting on the cold injector, which is working, but the rest of them are not working. the cold injector shuts off quickly and hence engine stops because the other injectors are meant to be running it by then. but it will run for a short while just on the cold injector.
this was the case with mine after a 16 year lay up. (74 1.8 same thing basically as yours).
it also ran perfectly when i parked it 1/4 of a lifetime ago (i sound like a dodgy craigslist ad !!!!)
i had cleaned the injectors but to no avial. pintels end up corroded. even a clean will not make them function, despite a test that said we had resurrected them.
i bought some new injectors and presto it ran.
that the injectors are not working could be electrical.
but after 10 years more likely the injectors are cactus if you have not replaced them (injectors are not on your list of things you replaced/renewed?).
and if they are not cactus, the hoses on the end of them will be and you would drive about 10 miles and
burn down.
