Thanks guys.
I tried using the dog bones with the FG brackets that came with the bumpers, but the fit was terrible - the rear bumper had a half inch gap between it and the car.
That said, even without the dogbones I have no idea how anyone uses the FG brackets that come with them - if you fit them flat to the inside of the bumper the angle for the bolts through the car is completely off, and if you mount them to the car and fit the bumper to them only about half an inch of the surface actually contacts the back of the bumper.
I can't remember who it was, but I'd seen someone here make custom brackets so I decided to do that myself. The front fits great, and the back would fit great if not for the tow hook bracket.
This picture's from the front, but I did the same for the rear (the only difference was I widened the angle of the aluminum L to fit by crushing it in a hydraulic press). The benefit of the front was, you can adjust the angle and then tighten the bolt through the fog grille holes - for the back it was more position, remove, tighten, refit, and then repeat if it was off.
[/url]
I'll try grinding some off the inside to see if it will help with clearance, and if not I'll probably just cut a hole and mount a tow hook.
Can anyone recommend a racing tow hook? Is the thread/fit universal?
