QUOTE(914werke @ Jun 7 2021, 08:16 AM)
QUOTE(mb911 @ May 31 2021, 11:49 AM)
QUOTE(914werke @ May 31 2021, 10:28 AM)
QUOTE(ClayPerrine @ May 31 2021, 08:43 AM)
One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914.
NOPE
Not the same. Similar but will not bolt up to any 911/914/6 solution nor the 914/4.
The Body of the muffler is identical, the flanges are specific to the 912e one yrs only HE's. They are still 3 bolt attachment but upside down from the /4 mounting.
Correct
@mb911 Ben before I begin a exhaustive (see what I did there
)search, I figure Ill ask the muffler expert.
Do you know if the spacing / or tube inlet measurement is the same for the 914/4 & 912e muffler variants ?
In other words if I mod a 914 2.0L banana to apply the correct flanges for the 912e will it attach / fit the 912e HE's?
They are not the same. 912e is about the craziest setup on the planet. They come in at an angle. Could it be modified to work ? Yes for sure. Would be a bunch of work. I could see that as a 8-10 hour project to ensure everything lines up , trial fit, weld etc.
