QUOTE(rbzymek @ May 30 2021, 02:19 PM)
My turn signals were not canceling so I looked up the switch part on AA and purchased the correct part and changed out the switch assembly (1975 former 1.8L now 2056). They function and cancel now but when I remove the ignition key the right front and rear turn lamps and side marker stays on. Insert key and turn to run and the three lamps go out and the signals function normally. Someone must have seen this one before. Any help would be appreciated.
Seems like when mine weren't cancelling, I had the screws a bit too tight.
The other makes one think that in a particular position, something is touching that shouldn't be??
