QUOTE(Mark Henry @ Jun 3 2021, 07:52 AM)
I'm collecting the parts but it's not on my high priority list, mostly because you have to take the dash right apart.
Below is some of the parts I've collected.
Ignition switch dash part, weld in mount, Restoration Design
Column clam shells, 914rubber
Early 70's column, used, lock receiver area needs to be modified/welded.
Mid 70's ignition switch, but I'm still looking for the wiring harness and it needs to be re-keyed.
Turn switch, used.
Wiper switch, used. Both could use new stickers.
Still need a steering wheel and hockey puck, plus likely a bunch of other little bits.
Any 914 steering wheel will work.
Clay
