I have a gremlin that I can't figure out. Have a FI 1.7L that has been rebuilt and all new Vacuum lines, new fuel lines, just updated to a correct part# NOS MPS and it holds 15in/hg forever. Adjusted timing. Checked AAR and it is working. When rebuilding gapped valves to spec.
I have read the threads and main assessment is either vacuum leak or rich/lean mix - could be others but starting with those first. I have clamped all vacuum lines to their attach points so wouldn't expect leaks from these. I read about a smoke (cigar) test, but need more understanding of how that works before I go buy some cigars.
Per https://members.rennlist.com/pbanders/idle.htm, engine stalling when warm says mix is too rich.
Question, my ECU doesn't have an adjustment knob on the exterior, is there an adjustment knob on the inside of the ECU? Want to start with this before I move on to other items..ev
