QUOTE(wonkipop @ Jun 11 2021, 05:33 AM)
there are two.
they are venturi tubes.
when the car is moving, neg air pressure drains any moisture out of the spare wheel well.
my guess is that the idea behind it is to drain melted snow out of the well if you change tyres in winter, ...... something like that. i mean what else would cause water to accumulate in the spare wheel well. the suction is not created by them bending backwards but by the slit aperture.
the tubes are i believe still available today from porsche, they drained the headlight buckets on a 911. and they used them on something else too which i forget.
you might be right about them not being in parts diagram. my mechanic recognized what they were on mine when we had it up on the hoist. i had to glue one of them up as it was starting to crack after all this time. but both were still there.
If I'm not mistaken, I believe they work on combination Bernoulli's Principle and venturi effect. I am probably over thinking but thought the bending (which they do when the car is at speed) would place the open slit at the trailing edge of an air foil created by the bending and perhaps maximize the suction of the air blowing by. Plus, fresh air blowing across the dangly bits probably feels good to the car.
Being an Aussie, you are forgiven for not knowing how else moisture gets in the frunk, but anyone who has lived in a cold and humid climate does. Condensation and frost get on every surface and will accumulate water in places like the frunk in surprising quantity. Luckily the cars were designed by Germans who know about such things
I got mine from 914Rubber.
