Would someone with the tubes and flapper boxes and all the pipes into the cabin be able to take photos to show how it all fits together please (a full system in place)
plus photos from the top showing the fan placement and position plus the routing for the tubes etc....
I have a box of parts minus some of the flexible tubing and I am trying to figure how it all goes together and what I am missing
thank you
dt
Front yard mechanic
Jun 5 2021, 01:57 PM
QUOTE(dt4 @ Jun 4 2021, 11:18 PM)
thank you
dt
It's hard to get a full photo of that search for the wire frame image
dt4
Jun 27 2021, 09:00 AM
It appears to me that the pin for the flapper box on the driver side is in the wrong way and that the cable connector should be on the top not the bottom when the tubes are assembled?
Could someone confirm please
Can the pin be knocked out and assembled from the other side?
dt4
Jun 27 2021, 09:01 AM
Does anyone have a pair of clamps that fit the heater tubes pictured please
dt4
Jun 27 2021, 09:03 AM
I am unable to figure out where these two shields fit, does anyone have a photo or diagram please
bdstone914
Jun 27 2021, 09:17 AM
QUOTE(dt4 @ Jun 27 2021, 08:03 AM)
Click to view attachment Those fit earlier cars. Are you back dating the system or sticking with the 75 heat exchangers. There are similar plates for the later cars.
bbrock
Jun 27 2021, 09:27 AM
And for a pic showing how the parts you have attach, here is a pic of my car. Note that one of the attachment points is missing on this part (since replaced with a better one), but the plates attach to the heads and heat exchangers.
dt4
Jun 27 2021, 10:02 AM
thank you for the picture that will help
I have a 75 1.8 so presuming the heat exchangers are correct for the year / engine
I'll use your picture to check
euro911
Jun 27 2021, 08:54 PM
1975 & 1976 had a different exhaust system than what it appears you have. Guessing that a previous owner back-dated the exhaust system. That's not an issue if you have all the correct parts.
The caps on the heater valves face inward towards the middle of the engine bay, and the activation levers are on top.
Obviously there's a left side and a a right side (mirrored images). I wouldn't try to modify the offending one ... just source the correct one (as needed). The one you posted is the passenger side.
Bruce Stone
@bdstone914 might have the clamps you need
Dave_Darling
Jun 28 2021, 12:24 AM
Can you post a pic of what your exhaust system looks like?
Or at least, tell us if it has F-pipes attached to the heads that point forward, bolting to a piece that does a sharp 180-degree bend, and has a single pipe with a triangle-shaped exhaust flange? (One copy of each on each side, obviously.)
Or do you have the type in the photos above?
--DD
dt4
Jun 28 2021, 12:31 AM
I will get the car back on the axle stands and take some photos
Thanks for the suggestions
StarBear
Jun 28 2021, 09:25 AM
QUOTE(dt4 @ Jun 27 2021, 11:00 AM)
Click to view attachmentYes, the cables go on the top of each flapper unit; the flappers are a matched, mirrored (opposite) pair.
dt4
Jun 28 2021, 11:40 AM
The flapper boxes and pipes
dt4
Jun 28 2021, 11:42 AM
The heat exchanger on the driver side
dt4
Jun 28 2021, 11:43 AM
The heat exchanger on the passenger side
StarBear
Jun 28 2021, 12:29 PM
QUOTE(dt4 @ Jun 28 2021, 01:40 PM)
Click to view attachmentLooks (?) like you have two of the same side (drivers?) boxes.
914werke
Jun 28 2021, 12:30 PM
QUOTE(euro911 @ Jun 27 2021, 07:54 PM)
1975 & 1976 had a different exhaust system than what you have. Guessing that a PO back-dated the exhaust system. The caps on the heater valves face inward towards the middle of the engine bay, and the activation levers are on top.
I typically flip the Valve side to side & orient the cables to the bottom for ease of service.
dt4
Jun 28 2021, 01:30 PM
QUOTE(914werke @ Jun 28 2021, 07:30 PM)
it didnt look as thought the cable on the drivers side was long enough to reach the underside of the valve
dt4
Jun 28 2021, 01:32 PM
QUOTE(StarBear @ Jun 28 2021, 07:29 PM)
they are definitely different, the tube that connects to the flexi pipe on the firewall is a different length and angle
rhodyguy
Jun 28 2021, 08:15 PM
One heat exchanger sits further back than the other. That's why the dif lengths. OEM controls wires I have bought were prebent correctly. 2 longs or 2 shorts cause issues.
dt4
Jul 23 2021, 01:42 PM
I fitted the heater tubes and flap boxes today along with the flexible pipes from the fan.
What an absolute bastard of a job that was, I guess they tend to fit the tubes when the engine is out to make getting at some of the bolts easier
dt4
Jul 31 2021, 11:50 AM
I have now connected the hear flapper boxes and cables together
when the lever is pulled up the flap opens, or is it closes? but when the handle is released the flapper pulls the handle back down
How should it work please?
