No start turning into No start Hell
Newb here getting to know my 914 and enjoying the process ,far far far from an expert just persistence is how I learn .I have to say I am at a loss here on what to do next and would really appreciate some help
Less than 1000 miles on rebuilt engine Dual weber 48’s
Trend with the engine getting harder and harder to start an occasional backfire just at start up
Hard starting progressed to a no start situation took the following actions in an attempt to resolve the issue
Battery tested No issues
Engine slow to crank, Replaced with Hi-Torque IMI-101N works Great turns nice and strong still no start
Oil changed while I had the car up
In case Car out of gas from a failed sender added 2 gallon to the ¼ tank reading still no start
123 Ignition Distributor installed (planned update before issues )
Checked and rechecked and checked again for TDC on Fan, and Flywheel
Verified spark with external spark plug
Carbs ,have gas Plugs (Bosch R6) wet after repeated attempts at a start
Pulled Dried and cleaned before reinstalling
Bottom Idle mixture tried 1 ½, and 2 turns out
Cleaned idle jets and main jets
Res tanks filling checked and adjusted floats for rest and drop per specs
can see gas squirt from the accelerator pumps
Engine still won’t start up after repeated tries the best I can get is a backfire but even that is rare
I am at a loss of what to try next , I could put the old dizzy back in but i had the no
start issue before I replaced it I could try adjusting the idle mixture , but thinking that would really only come into play if the engine was running .
I am out of idea's and need some help
