EDIT: I found a bolt that will work for now. Thanks for the replies
The replacement strut I'm installing on HOWARD is missing the pinch bolt to secure the ball joint. Anybody have a spare one laying around?
mskala
Jun 9 2021, 01:13 PM
QUOTE(euro911 @ Jun 9 2021, 02:38 PM)
If I didn't lose them, I have a box of new ones. Will check stash when I get home.
914Sixer
Jun 9 2021, 04:46 PM
Standard 12.9 bolt
Jun 9 2021, 05:08 PM
QUOTE(914Sixer @ Jun 9 2021, 06:46 PM)
Standard 12.9 bolt
Coarse thread
mskala
Jun 9 2021, 05:35 PM
I found the box. Also confirmed looking at Pelican. The proper bolt is M10 x 30mm, grade 10.9 (though higher is not a problem). If you can't get that at a local hardware store I can send you a pair.
euro911
Jun 18 2021, 01:10 PM
I found a 10x30mm stainless bolt in my stash that will do the trick for now. I just needed to get the ball joint clamped in so the car can get winched up onto a trailer. When the other repairs are done, I have a pair of 'late' struts earmarked for installation.
Thanks for all the replies, guys
Jun 18 2021, 01:13 PM
Yea, it’s good to have extra suspension parts to make a tub a roller.
euro911
Jun 19 2021, 02:09 PM
QUOTE(mepstein @ Jun 18 2021, 12:13 PM)
In retrospect, I should have kept those trailing arms that I sent your way, Mark
