bobforman
Jun 11 2021, 04:43 AM
My clutch cable appears to be stretching to the point I put a sleeve between the adjusting nut and the actuation lever to make it work. Am I wrong in thinking this may be the beginning of the end for the part and that total unraveling my be in the future?
Mark Henry
Jun 11 2021, 05:05 AM
No you're not wrong, get a spare cable now.
bdstone914
Jun 11 2021, 05:56 AM
QUOTE(bobforman @ Jun 11 2021, 03:43 AM)
It may be a broken clutch tube attaching point in the tunnel.
Buy yes get a new cable. If you do have to repair the attaching point you want to use a neew cable.
rfinegan
Jun 11 2021, 06:04 AM
Driving without a clutch cable is not fun....Possible, but not fun. Get one now before you have to test the ^above ^. They are not expensive and can be installed with simple hand tools and a floor jack in less than an hour
Spoke
Jun 11 2021, 08:30 AM
I had to adjust the clutch cable several times before it snapped. As others said, if the clutch tube is secure it would be a good time to buy another clutch cable.
dr914@autoatlanta.com
Jun 11 2021, 09:10 AM
I second this
QUOTE(bdstone914 @ Jun 11 2021, 04:56 AM)
ndfrigi
Jun 11 2021, 09:24 AM
and not really hard to replace the clutch cable.
bbrock
Jun 11 2021, 09:39 AM
Related question. How much does a new cable stretch before it settles down? I have a new cable from Porsche and I reinforced the clutch tube attachments during my resto so am pretty sure that is good. During the first couple hundred miles I adjusted the cable twice to take up stretch. It seems to have stabilized now with an additional hundred miles on the clock, but I'm still in that vary paranoid phase of putting a full resto on the road. Should I be worried about this cable?
orthobiz
Jun 11 2021, 09:45 AM
I have had clutch nuts that were possessed and would unwind from the end of the cable a little at a time. Make sure you have a new nut, 11mm, it has a delrin insert to make it lock a bit. Never reuse the nut. Carry a spare nut.
Maybe measure from the end of the nut to the end of the cable to see if this is your problem instead of a stretching impending failure cable.
Paul
JamesM
Jun 11 2021, 09:52 AM
QUOTE(orthobiz @ Jun 11 2021, 07:45 AM)
Paul
I have always double nutted clutch cables to keep this from happening
Root_Werks
Jun 11 2021, 09:57 AM
QUOTE(ndfrigi @ Jun 11 2021, 08:24 AM)
Can be a road side repair. Always carry a spare clutch and throttle cable. Two fail points that ruin a drive really quick.
davep
Jun 11 2021, 08:31 PM
Clutch tube security check is to have someone operate the clutch while another person observes the movement (if any) of the end of the tube where it exits the firewall. It usually breaks the attachment here first, then fatigues the attachment to the tunnel wall ahead of the gear-shift.
Cables can stretch, but usually not a great deal. Great changes in adjustment usually are the failed tube.
Mikey914
Jun 11 2021, 08:35 PM
Actually the shortest ground if your strap isn't working (or missing from the transmission to body) is the clutch cable.
I suspect that is where your issue lies.
I got the privilege of driving without a clutch in the Dalles WCR.
It will heat up and stretch. Other than that the cables do not stretch any appreciable amount.
