QUOTE(bkrantz @ Jun 11 2021, 05:24 PM)
I was able to remove and install the side mixing boxes and defroster vents while still connected. The round clips can be difficult and the plastic half-studs they hold together are fragile.
My suggested removal order:
gas tank
cowl support struts
all the vent hoses
undo all the control cables (label them and get lots of photos first)
both side mixing boxes (a tight fit but can be removed with the ducts attached)
center air box (also a tight fit, especially when installing)
wiper motor and frame as a single assembly
The glove box can be removed with the dash in the car, but is another tight challenge. If you are removing the dash, leave the glove box for later.
Wasn't removing the dash.
I have the strap loose, and two screws for the hinges, but seems stubborn about coming out. Not sure what is holding it on the front side?
