QUOTE(second wind @ Jun 11 2021, 06:34 PM)
Hello out there....the thought of new fuel injectors sounds so good if they are legit.....anyone tried there before? Are they quality? Where are they made? Would be wonderful if all systems are go....please share your experience. Thank you very much.
gg
I'm no 914 guru, but the following link is everything that I experienced with those injectors. I put them on a 74 2.0. The car ran great. Full disclosure: I also removed, cleaned or replaced everything above the intake, including manifold gaskets, runners, plenum, & airbox. And sent the throttle body out for rebuild. So those things didn't hurt the performance either. Hope this helps. GLWT!
P.S. I know other threads have discussed this recently, so hopefully others will chime in now that they have had time to install the injectors.
http://www.914world.com/bbs2/index.php?showtopic=343970
