I did this last night! Yes, #1 & #3 are easier to find using the TDC mark on the fan. With all of my spark plugs out and in 5th gear I was able to locate TDC on #2 & #4 visually with a light, peering into the spark plug hole. The distributor will get you very close and visual back and forth got me there perfectly. Pretty easy too.
FYI, warm the engine up BEFORE the leak down testing, and EVERYTHING is easier with the engine cover removed!
However, as I chase down an incredible lean ide and a lean hicup/hesitation leaving stop signs, I was not impressed with my leakdown numbers on 2/4 of the cylinders. I then went ahead and checked the compression of each cylinder, again lower than I'd like to see. I recently adjusted the valves but will pop the covers off and recheck and redo all of my leakdown/compression again to make sure a valve hasn't tightened up.
Have fun, you got this!
