QUOTE(lexus914 @ Jun 22 2021, 02:05 PM)
I have ‘73 914 2L with factory FI. My fuel pump fuse all of a sudden started to blow.
I checked my AAR and it functions as it should. I checked the lead and is does not appear to be compromised . I checked the resistance and it is reading 13. What else do I need to check?
Best solution is to disconnect the cars wiring to the pump and run independant supply to battery and test that way then you know the pump is ok.
Have you tried another relay for a proven working one from elsewhere on the car ?,removing a headlight one is simply,good luck.
