QUOTE(davep @ Jun 26 2021, 02:20 PM)
Koni struts are designed for Koni inserts and Bilstein struts are designed for Bilstein inserts. In both cases I don't know of another supplier making parts to fit. Boge struts are designed for Boge inserts, but both Koni & Bilstein make inserts that will fit; I'm sure there are other suppliers that make inserts that fit as well. But in any case, the inserts are designed specifically for the strut. So a Koni insert for a Koni strut will not fit a Boge strut.
If you search the Bilstein catalog for 914 (even 914/6), you will find inserts for only Boge struts. But if you search for 911, you find inserts for either Boge or Bilstein struts. The cartridges look very different. I have Bilstein in my Boge struts and they dropped right in.
