QUOTE(rosenfe @ Jun 26 2021, 11:08 AM)
Car new to me. Cleaning up grounds, now have rear turn signals. Front signals have 2 plugs in fender well. One with three female plugs and one with 2. Light fixture has only 3 pronged male. Question is what is 2 female plug for and what wires go to male plug. ?
The wire that has 3 female connectors is to the turn signal. The one with 2 plugs goes to the side light.
On the left turn signal you should have a Brown wire (ground), a black and grey (Turn signal) and Grey/black is your parking light. Then you have a brown and a grey/black wire that run to the side marker light.
On the right turn signal you should have a Brown wire (ground), a Black/green (turn signal) and a Grey/red wire ( parking light) Then a brown and a Grey/red wire to the right side light.
