jims914
Jun 27 2021, 09:08 PM
Hello,
EZ way to lower front end, with out having to moving strut from spindle and not having a problem with out a lot of bump steer.
euro911
Jun 27 2021, 09:46 PM
You can adjust the torsion arm bolts on the cross member to lower the front end. If you drop it too far, it's recommended to have the suspension aligned.
There are inexpensive, and expensive bump-steer kits available, The less expensive kit consists of thicker washers and longer bolts for mounting the steering rack.
https://www.pelicanparts.com/More_Info/PELR...AiABEgJO5PD_BwEThe more expensive kits deal with the issue at the tie rod ends ...
https://www.pelicanparts.com/More_Info/RENS...ASABEgIA1PD_BwEhttps://www.vividracing.com/-p-151379338.ht...CCABEgJgQ_D_BwEhttps://www.vividracing.com/-p-151379338.ht...CCABEgJgQ_D_BwEHere's a good thread on the subject ...http://www.914world.com/bbs2/index.php?showtopic=98820&st=0&p=1207838&#entry1207838
jims914
Jun 27 2021, 11:51 PM
QUOTE(euro911 @ Jun 27 2021, 08:46 PM)
Thanks for the information, good treads.
914Sixer
Jun 28 2021, 06:12 AM
Porsche did not get it right for everyday driving?
AZBanks
Jun 28 2021, 11:17 AM
You can lower it using these bolts.
