Hi World -
As I'm working to dial in my car, I noticed that there seems to be a bit of play in the rack. You can see the amount of movement and (turn it up) hear the related "clunk". Before you ask:
- the steering is not locked
- all the steering shaft universal joints are tight
More info:
- When I move the steering column as demonstrated with my other hand on the rack's input shaft, I can feel the appropriate amount of movement at the rack.
- When a buddy took over moving the steering column, I reached under the car and grabbed one of the tie rods. I could feel the "clunk" but couldn't detect any movement of the tie rod.
So. Is this even close to normal? Doesn't seem like it.
Assuming not, is this something that can be adjusted out? Or is this an indication that the rack needs rebuilding?
Any help appreciated.
Chris
https://www.youtube.com/watch?v=bnm1n_q3sEE
