Full Version: transmission side output seals
Hammer920
Got my side output seals in, one question the bolt thats in the center, looking at diagram does it just un screw , Or is there a nut with a cotter pin through it inside the tranny which way does ti come out to replace the seal? gonna take the tranny off the rebuild and also replace the seal in front too. also need to find crush washer for the speedo any suggestions pic of tranny in before and after post #1 pic. biggrin.gif
Thanks for your input
Red-Beard
You have to prevet the flang from turning. I usually use an old punch, but a crappy phillips screw driver could be used. Insert through one of the hole and into the case webbing. Now you can turn the bolt.
