Jamie
Jul 10 2021, 05:19 PM
.....15mm wheel spacers for the front of my 73 teener. I want to eliminate a slight rub inside the wheel well from my 205x65 15" tires, have plenty of outboard room to widen the track up front. Only ones I have found were not hubcentric and created significant shimmy at speed. Do y'all have any trusted sources to recommend?
914Sixer
Jul 10 2021, 06:03 PM
NEVER liked wheel spacers. Compare the length of your tie rods side to side. You might have a little adjustment room there. 914's bodies are KNOWN to be a little off side to side causing tire rub.
Jamie
Jul 11 2021, 06:46 AM
QUOTE(sixnotfour @ Jul 10 2021, 03:49 PM)
Thanks "sixnotfour," that is just exactly the info I needed, and the price is right!
