Full Version: Another fuel filter question - 1.7
jrmdir
Hello:
Most of what I'm seeing is to go with the Mahle filter that has 8mm fittings on each end:
https://www.pelicanparts.com/More_Info/3111...I=5882&fs=0
But the supply line from the tank is larger (9mm?) I see that Tangerine has metal tube reduction adaptors but what are people doing otherwise to fit the larger rubber fuel lines onto this type of filter? Just crank down on the clamp?
TIA.
Ron
ChrisFoley
The factory had a rubber reducer just before the filter. They are NLA unless Auto Atlanta is getting them made.
Don't attempt to fit the wrong size hose on a fitting. That's a recipe for disaster.
jrmdir
Thanks for the quick info. I'll check with AA but wonder if something like this would work: https://www.amazon.com/Reducer-Hose-Brass-F...s/dp/B078QZ2MJC
JOEPROPER
QUOTE(jrmdir @ Jul 12 2021, 02:03 PM) *
That should work, but racerchris @chrisfoley makes them too. That's where i got mine.
JeffBowlsby
QUOTE(jrmdir @ Jul 12 2021, 11:03 AM) *
Don't get us started on barbed fittings used in a pressurized fuel hose system.
