QUOTE(Mowog4 @ Jul 14 2021, 09:55 AM)
I can tell I am quickly getting old, the poly bushings in my car squeak while I drive the car which is driving me nuts. I had a shop pull them out and grease them inside and out, worked for a couple days then the noise was back.
Any choices other than rubber, or is the rubber a good alternative?
@Mowog4 Are you referring to front or rear bushings?
The rear bushing are now carried b Restoration Designs. They come from the same company that supplies Elephant Racing.
Not as pricey as Elephant.
Installing the rears is quite a chore. I will be posting a thread with the tools I made to install them.
914 Rubber front bushing are good. I would not use Uro fronts again. Had too man problems with them.
@76-914
