EXCELLENT article! Aligns with everything I've studied about synthetics over many years.
One question: Heard many times that synthetics have additives that dinos do not that break down brass - and old engines have bronze parts in them that are slowly broken down by synthetics.
Anyone know the truth about this?
As I am an Amsoil dealer, I'm going to go to Z-Rod, unless there are brass parts in the Type IV engine and the brass degradation is known to be true. Which weight?
Most damage to an engine is done at one of two points: start-up - due to lack of oil on the metal, and Max RPM, which most of us do not do. Synthetics stay on the metal better, so they are much better at start-up than dino oil. And, 10W is better than 20W at start-up, especially in colder temps. 10W in winter and 20W in summer for those of us who live where there are winter climes?
A picky point - you all know I am anal retentive by now, right?
Author says,
"Oil does not break down under normal use. This is true of both dino and synthetic oil and is also the reason why you take oil to the Recycling Center and not the trash dump. So if oil itself doesn’t ever degrade....."Absolutely true.
But later he says,
"With head temperatures normally between 300-350 degrees, synthetic will not breakdown while lubricating the valve train components at the heads." which IMPLIES that dino oils do break down in the high temps of the heads.
GN
QUOTE(bbrock @ Jul 26 2021, 09:09 PM)
