@914boss Some additional info to rule out other possible culprits:
- what size/type is your radiator?
- what size lines are you running?
- What's your fan set up? One or two?
- How are your fans triggered?
- let's see pics of your air inlets, outlets, rad shrouding, etc.
I'm running a Renegade radiator, 1.25" lines (a mix of Gates green stripe and aluminum hard line) and Meziere remote electric water pump. No thermostat and my ECU runs the Renegade fans. Both come on/go off at the same time.
It works well on a street driven, 500+ hp LS3. Freeway temps are actually a little under where I'd like them.
I agree with others that you likely have air in the system. Or there's an issue with your cooling set up - like air not ducted well enough. I'm not saying that's the case, just something to be sure is nailed down.
Keep us posted on your progress and best of luck resolving this issue.
