Thanks to an eagle-eyed @rgalla9146 I discovered that the outer fan pulley on my build doesn't match the inner fan/pulley. I've been doing research trying to track down exactly what I need and I thought I'd document it here in case I miss something or if anyone else has options.
The pickle I found myself in is that my engine was a core and did not come with the fan/housing. Through the build I have sourced missing parts and always specified the year/motor I have, to try and avoid this.
Despite this, the fan I have and have assembled is a later version. The outer pulley and the crank pulley are the correct versions, but it's also more expensive and time-consuming to try and source and replace the fan.
I can source an outer fan pulley that matches the fan, but then the pulley size difference means that the standard belt lengths aren't right for the application.
Early - crank pulley 116mm, belt is 9.5mm wide x 710mm long
Late - crank pulley 127mm, belt is 9.5mm wide x 725mm long
I believe 76-77 was the changeover year.
Using the early, smaller, belt on my setup would end up slightly too big. Meaning reduced shims and earlier belt change intervals... if it would even work.
I'm looking at late crank pulley options, but as you can expect in the 6-cyl Porsche world, nothing is cheap.
So the question is, does anyone have first-hand experience using the late fan pulley with the early crank pully and a 710mm belt?
