Have a 1970 that I need a steering column and the wiring that hooks up to the ignition and leads eventually to the wiring harness/ fuse panel.
Does anyone know if A column from the 1971 would work for my car? Not sure if it’s compatible although the steering lock mechanism and ignition look correct. Just want be sure the wiring/ turn signal mechanism matches up. Thanks in advance! Todd
