I've been trying to get my headlights to work for a while, now. I can't find anything wrong, other than they don't turn on. It's nothing to do with them poping up or corner markers, blinkers, just the headlights. I like to explain with photos so here it is. The number 1. wire is from the ignition switch, to the relay and has 12 volts. The number 2. wire goes directly to the right headlight (bypassing the relay and fuse). If I connect the number 1. wire to the number 2. wire, bypassing the relay and fuse, the lights don't work. If I connect my power pack directly to the number 2. wire, the lights work. I'm not the best electrician in the world but what am I missing? Thanks for any sugestions.
