QUOTE(Dave_Darling @ Jul 29 2021, 02:50 PM)
Your tach is from a 73. In the 73, the arrows are two separate indicators; only one will flash at a time when the turn signal is on.
1974 cars had a tach with only one turn signal indicator, and it flashed with either turn signal on.
Some early 74s had 73 gauges installed from the factory. They added a jumper so that both arrows would flash when either turn signal was on.
Either your 74 is an early car, and something has happened to the indicator light circuit, or it's a later car that someone swapped a 73 tach into, and they didn't hook up the indicator light. (Do all the other main gauges have silver cones in the middle of the gauge?)
There have been posts here about how to re-wire the indicator circuit to work both lights separately, if you want that.
--DD
Thanks, Dave- you are a plethora of information as always. Yes, my car is a very early '74 with an August '73 build date. All of my gauges are the silver cone type. I don't understand why the factory would have jumped the wires to make a perfectly good indicator flash illogically (both arrows illuminated)…???... Nevertheless, how many of the lamps inside the gauge illuminate the arrows- one or two?
Ansbacher
