Hi everyone.
I apologize for yet another 123 setup thread
I just spent an hour reviewing the GB thread, and a couple of other 123 threads.
my motor is a stock Djet motor, with 1975 djet components
I bought a used 123, from Jim's well running car
his car is also Djet, on a 2056 I believe
the distributor is the -4-R-V-IE model with the vacuum nipple.
it came set to position #4, from Jim's use.
as I read all of the threads I could find... there are a lot of different recommendations for which Djet setting to use.
I've seen:
#1, #2, #3, and letter A all recommended by different members
(in some of the threads it was hard to track which owners were 1.7 vs 2.0)
I have not yet pulled my distributor. I need to do that to verify which model number is installed. I believe that I checked it years ago when I bought the motor and anticipate it will be the stock distributor for a 2.0/djet/1975. But need to verify
I hope to install in the morning.
because it is so easy to change the setting now, while the 123 is not installed.. I would love to gather more information for this setting... I intend to use the Advance-vacuum as that is how the car is currently running.
(yes the distributor has the spacer)
thanks in advance
brant
