QUOTE(Speedo @ Aug 2 2021, 04:46 PM)
My diagram is for a 914-6 and maybe it differs from a 914 diagram?
Very much so. Your '72 /4 should be close to a '71 /4.
Click to view attachment CODE
1 Battery
11 Headlamps
12 Fog lamps (optional)
13 Blinker-, clearance lamps
14 Tail-, brake-, blinker-, back up and side marker lamps
15 License plate lamp
16 Interior lamp
17 Side marker lamps
18 Trunk light rear
22 Transistor revolution counter
23 Speedometer
26 Steering ignition starter switch, dimming switch with signal button in steering wheel
27 Combination relay
28 Light switch
31 Warning light switch
33 Door contact switch with buzzer contact
35 Brake light switch
36 Switch for fog lamps (optional)
39 Backup light switch
47 Direction warning blinker indicator
50 Relay for retractable headlights
53 Relay for fog lamps (optional)
60 Fuse box
62 Motor for actuating retractable headlights
82 Ground connection point A
83 Ground connection point B
84 Ground connection point C
85 Ground connection point D
90 Regulator plate
Fuses:
1 High beam left
2 High beam right
3 Dimmer left
4 Dimmer right
5 Clearance light left
6 Clearance light right
7 License plate light
8 Brake-, blinker-, backup light, windshield wiper, cigarette lighter
10 (Fog lamps)
11 Interior light, warning light, buzzer
12 Motor for actuating retractable headlights
Click to view attachmentCODE
1 Battery
2 Starter
3 Alternator
5 Ignition distributor
6 Ignition coil
7 Spark plugs
9 Gasoline pump
21 Combination Instrument
29 Wiper-washer switch
30 Fan and separate heater switch
32 Brake warning switch
34 Hand brake contact
37 Switch for heater blower
40 Oil pressure switch
41 Diode
42 Oil temperature indicator (option)
48 Thermoswitch
49 Indicator for fuel gauge
54 Relay for fresh air blower
56 Wiper motor
59 Cigarette lighter
60 Fuse box
63 Fresh air blower
64 Horn
65 Heater blower
66 Buzzer
71 Electronic control unit for fuel injection
72 Pressure sensor
73 Electric injection valve
76 Temperature sensor I
77 Temperature sensor II
78 Supplementary air valve
79 Throttle valve switch
81 Cold start valve
81 Ground connection point A
86 Sportomatic
90 Regulator Plate
Fuses:
8 Brake-,blinker-,backup light, windshield wiper, cigarette lighter
9 Fresh air blower, horn
10 (fog lamps)
12 Retractable headlight motor
