The car wont idle when cold.
I have warmed the engine to running temperature and adjusted the air screw on the throttle body and the screw on the ECU and the engine idled well when hot, but since then it will not idle when cold and cuts out if its nor revved, I have spayed brake cleaner into the engine bay to check for air leaks but I cant find any.
I need to get the idle working well and the idle CO down to under 4,5% to pass the roadworthy test.
Anyone got any ideas on what to do?
