QUOTE(rgalla9146 @ Aug 2 2021, 01:24 PM)
Some time ago one of the restoration threads here included pictures of a 914 fuel tank
that was done by tank specialist shop.
There were pictures of the interior of the tank that showed a perfect uniform
grey/bare metal surface.
I'm hoping someone remembers and can direct me to that thread or the specialist
that did the work.
Anyone ?
TIA
Rory
@rgalla9146 I have used Evaporust to restore gas tanks. Takes 2-3 gallons and you need to seal all openings. Rotate it to rest on bottom, each side, top bottom, and ends. You can dilute it with water to get a higher fill line. Drain, rinse and dry with a heat gun or sun to avoid flash rust. Wa lm mart carries it at the best price.
