(troubleshooting electrical problems over the Internet is such a PITA, and I rararely jump in cause of that...but I do like a challenge...)
QUOTE(Geezer914 @ Aug 6 2021, 12:55 PM)
The car Starts and runs for a few seconds with the Airflow meter unplugged.
Right. So.
"Starts and runs" implies fuel (pressure) for only a short duration.
As noted prior, (to my understanding) the AFM controls the fuel pump relay circuit (and, therefore, is not controlling the fuel pump relay circuit when it's unplugged) and yet the pump runs during the cranking circuit (because the relay cicrcuit bypasses the AFM and keeps the fuel pump relay engaged when the starter circuit is engaged). It would follow that the fuel pump relay is subsequently turned off when you release the key from the start circuit.
Therefore...just humor me...please jump the fuel pump relay and have it running all the time to see if the car continues to run after releasing the starter switch.
