Hey guys. Getting back to the 914. Life (and other rust buckets that need saved) get in the way.
Engine:
1911cc Dellorto dual DRLA
Problem:
When I crank it just “puts” or “puffs”
I’ll try to make this short and sweet.
-I had the car running about a month ago.
-removed carbs for cleaning and linkage adj.
-electronic ignition.
-bench set carbs
What I checked:
-voltage at coil (Bosch blue)
-have spark (plugs are blackish- smell like fuel) but cleaned and gapped
-perfect fuel spray from jets
-check ohms at coil
-ignition switch is less than a year old.
I raised the idle screws, etc to test
The only think I can think is my timing is off? (I have tried adjusting!)
Can I not static time using the typical method with Electronic ignition?
I have my timing set to a scribe mark I made previously.
after I used my timing light to set 27deg btdc.
Am I a dummy?
Am I missing anything? No matter what I do it cranks and “puffs” - meaning I can hear air coming out of the exhaust.
