MarkV
Jul 25 2005, 12:12 AM
I am trying to clean up the hacked up front trunk floor. This is the solution I came up with. It was over 100 degrees here for the last 39 days so I need to keep the A/C. I just don't like the nasty installation. I am also converting to the better style condensor & a rotary compressor.
MarkV
Jul 25 2005, 12:13 AM
asdf
MarkV
Jul 25 2005, 12:14 AM
gh
MarkV
Jul 25 2005, 12:16 AM
as
MarkV
Jul 25 2005, 12:17 AM
sd
MarkV
Jul 25 2005, 12:19 AM
fg
MarkV
Jul 25 2005, 12:23 AM
Ran out of weld gas. Still need some more grinding, a little seam sealer & some yellow paint.
rhodyguy
Jul 25 2005, 12:33 AM
props man. looks good. bonus credit for enduring the heat. rust treat, prime and paint and you're cool.
k
tdgray
Jul 25 2005, 06:20 AM
What wrong with your welds
They make mine look like ultimate
redshift
Jul 25 2005, 06:26 AM
Huckster! Had me psyched!
Looks great.
M
Automotive Hindenburg
Jul 25 2005, 06:59 AM
Looks great, much more sturdy then the stock install. I like the rock gratem a lot, I've got a bunch of bent fins that is just cry for one. Since your fabbing stuff up, how about making a little scoop to catch more air when your moving. What kind of condensor are you switching to?
I added an RPM switch to my install that made a world of difference. I'm running carbs so my idle rpm's flucturate a lot. The switch shuts off the compressor at rpm's lower then 800 and higher then 4200. I don't have to worry about stalling out my motor anymore when the rpm's drop and I don't have to run a stupid high idle.
bd1308
Jul 25 2005, 08:31 AM
i need to come up with a idle step-up system for carbs....
redshift
Jul 25 2005, 08:35 AM
Yes Britt...
bd1308
Jul 25 2005, 08:37 AM
morph
Jul 25 2005, 09:28 AM
from all the 914s that i pulled apart with.the one thing i allways looked at and hated.was A/C installs.they allways looked so HACKED,and i would think."this was done at a porsche dealership?" nice improvement,and btw your welds dont look bad.practice man,practice
james
914GT
Jul 25 2005, 09:36 AM
Looks great Mark! When you're done, you can come over and finish installing my A/C.
MarkV
Jul 25 2005, 11:28 AM
QUOTE (914GT @ Jul 25 2005, 07:36 AM) |
Looks great Mark! When you're done, you can come over and finish installing my A/C. |
Thanks Guy. Happy to help you work on your A/C. I need to find a local source for hoses and fittings. All of the hoses on my car need to be replaced.
Dad Roberts
Jul 26 2005, 09:26 AM
Please excuse my ignorance on this subject but from the pics it appears your intake for the condensor is at the front , with the air exiting at the rear of the same fixture? I know NOTHING about a 914 A/C setup. I have considered a similar setup on the pan of my VW, but not having to exit the air as you have. I was afraid of pulling the air from there because of road surface temperature. Is this the normal practice for 914 A/C? If so......I'm back to plan A.....
..............Thanks for any help........Dad
scotty914
Jul 26 2005, 09:43 AM
QUOTE |
Is this the normal practice for 914 A/C? |
yup that is how they did it. i would like to see how a condensor setup like a gt oil cooler would work. air in the front holes and air out a small hole in the floor
johnmhudson111
Jul 26 2005, 10:51 AM
QUOTE (scott thacher @ Jul 26 2005, 10:43 AM) |
QUOTE | Is this the normal practice for 914 A/C? |
yup that is how they did it. i would like to see how a condensor setup like a gt oil cooler would work. air in the front holes and air out a small hole in the floor |
Could the condensor not be mounted on the engine lid with a fan to help the air flow? How much impact would this have on engine operating tempatures? I was thinking of putting AC into the 72 with this arrangement instead of cutting up the front trunk.
MarkV
Jul 26 2005, 01:59 PM
QUOTE (Dad Roberts @ Jul 26 2005, 07:26 AM) |
Please excuse my ignorance on this subject but from the pics it appears your intake for the condensor is at the front , with the air exiting at the rear of the same fixture? I know NOTHING about a 914 A/C setup. I have considered a similar setup on the pan of my VW, but not having to exit the air as you have. I was afraid of pulling the air from there because of road surface temperature. Is this the normal practice for 914 A/C? If so......I'm back to plan A..... ..............Thanks for any help........Dad |
The rear exit has a metal flap angled toward the rear of the car. It hangs down 1-2" below the car and forces air out of the rear opening.
MarkV
Jul 31 2005, 03:50 PM
More progress
MarkV
Jul 31 2005, 03:51 PM
Yellow
MarkV
Jul 31 2005, 03:52 PM
last
Oled
Jul 31 2005, 04:18 PM
The engine lid is for all intents and purposes a dead air spot. You can put the condensor anywhere you want if you have a big enough fan to move air. If it is on the lid you will be adding heat to intake air, not an ideal situation.
914GT
Jul 31 2005, 04:57 PM
Damn Mark. That's lookin' good man! I finally painted the red car's hoods today. It is too damn hot to paint.
914rrr
Jul 31 2005, 07:50 PM
Why not put the condensor in the rear quarter panel using something like the 911 AC upgrade kits?
D1A3
Jul 31 2005, 08:39 PM
I was thinking the same thing! I'm wondering how dificult it woudl be to put a condenser in front of the rear wheels. Looks like it might work. Anyone know of this ever being done?
--Jason
