Just noticed that my brake lights are on when the ignition is on. What are the usual suspects? Thanks.
Spoke
Aug 6 2021, 10:50 PM
The single brake switch is located on the pedal cluster. It has an arm which contacts the brake pedal lever and may need to be adjusted.
bobforman
Aug 6 2021, 11:44 PM
QUOTE(Spoke @ Aug 6 2021, 09:50 PM)
Thanks, Spoke. I'll dig into that tomorrow.
Mikey914
Aug 7 2021, 12:22 AM
It's like a Deadman s switch. Contact is open, as long as it's making Contact the light will be off. . It's spring loaded to close. So the pedal is pressed and the circuit closes and the circuit is complete.
Probably just needs adjusting.
bobforman
Aug 7 2021, 09:15 AM
QUOTE(Mikey914 @ Aug 6 2021, 11:22 PM)
Thanks, Mickey.
rhodyguy
Aug 7 2021, 11:25 AM
Or the arm is on the wrong side of the disc on the rod.
