Posted only build-thread with photos
Posting a 'How-to' regarding the removal of the front-trunk pull-handle. Usually, this is done for cleaning and lock replacement, or in my case - both. Looking through the site, I felt like this last part of the project is unrepresented, so sharing the steps I took to remove. It's pretty easy, and only take about 5-minutes.
For the first step, I don't have a picture, you need to make sure you can access the bottom of the handle to remove 1x flat-head screw. This means you might have to remove your speaker-grilles or anything blocking the bottom of the handle. It's pretty short, and only needs a few turns.
Next, move to the front trunk and loosen the bolt that holds down the pull-wire, located inside the mechanism that locks the front-trunk. Straightedges the wire a bit, as much as you can, so it won't 'drag' inside the wire guide. Next, loosen the Phillips-screw that holds the wire-guide on the outside of that same mechanism.
Now, move to pull the handle out of the slot. You only need to pull it out about 6-8 inches. From here, you'll notice that the handle is 'theaded' onto the release wire. Note more-or-less where it is so you don't have to re-adjust when you install the handle. All you need to do is rotate it a few-times, and it will disconnect.
