Hello
Can someone kindly tell me … see pic.
1. The bolts that hold this together, should I use lock tight on them. The heads arent drilled to wire fasten for back up safety.
2. torque spec for the bolts. ? Assuming it’s the same on both ends of the axle ?
Close to finishing up my caliper/ brake/ rotor/ bearing install on all four corners Click to view attachment
