QUOTE(Ansbacher @ Aug 11 2021, 02:15 PM)
QUOTE(VaccaRabite @ Aug 11 2021, 10:53 AM)
When you are doing your adjusting make sure the engine is warm. Otherwise you will have an awesome idle while the car is sitting in your driveway after start up, and a 2000 rpm idle 15 minutes later when you come to the first stop sign.
Zach
Wow, I wish I lived in your area. My first stop sign is 300 feet down my road. Then another, and then the stop lights start
Ansbacher
I exaggerate. But I do have a good 5+ mile warm up route that only has 2 stop signs and 200 feet of elevation gain over 1/4 mile.
And getting your base set cold isn't bad so long as you expect the atrocious idle after a warmup drive. Then once you are fully warm turn the idle back down, make sure you are sill balanced (you should be) and you are good to go.
Expect to have to dance on the throttle starting it and going through warmup once you have idle set at hot idle. If you are unfamiliar with this, its it's disconcerting the first time. But once you learn the dance, all is good. For me it was:
Pump. Pump. Pump. Foot in a bit. Crank crank crank fire.
One of the best parts of fuel injection is letting myself forget the cold start carb dance.
Zach
